11-20-2011 12:09 AM - edited 03-07-2019 03:29 AM
hello guys....I have a very simple query please help me to find out:
I have only one IP series 192.168.1.0/24
and there are 4 Routers, 8 Switchs and 8 PCs which need to configured, in each Router there will be 2 Switchs with two FastEthernet port has to be connected and In each Switchs there will be 1 PC. And the Switches configuration has to be default. Please help me to by given the command of the routers with IP addresses.
Router1->0/0 ->SW1-> PC1
Router1->0/1->SW2->PC2
the goal is PC1 has to pingable to PC2
Thanks in advance....
Solved! Go to Solution.
11-20-2011 12:16 AM
Abid,
do you already have drawn down a plan of your network topology?
1 Network, 4 Routers, 8 Switches and 8 PC sounds a bit like killing the fly on the wall with blowing up the entire house.
Please provide proper details, if you intend to make a subnetting of your 192.168.1.0/24 network.
David
11-20-2011 12:16 AM
Abid,
David
11-20-2011 01:02 AM
Hello David,
Yes its basically a testing purpose what we are trying to deploy in a Lab. can u please help me out by given the recommended routing commands... infact I am facing the problem when I am putting the IP address...
when I am putting the ip address on interface0/1 then it says that ip overlapping...
thanks for ur reply...
11-20-2011 01:09 AM
Dear Abid,
of course it says "overlapping". this is a router which connects and forwards different networks.
Configuring 2 IP addresses from the same network on 2 FE on one router doesn't make sense at all
as the router in this case can't figure out which one of the 2 FE is the "real" responsible one and on which to route.
Thus, your approach will only work to implement a proper topology involving subnetting.
can advise please what model of Routers you have and with how many FastEthernet interfaces each one is equipped?
Thanks & Best Regards,
David.
11-20-2011 02:08 AM
Hey David,
Thanks for understanding my problem ...
so in this scenario what will be the router command to put the IP address when I was input ip address 192.168.1.1 for FE0/0 then it taking...but when I am putting 192.168.1.2 on FE0/1 its not taking....I just want to know why its not taking and what will be the commands on that scenario...i wants to configure two FE .
Thanks for replying sir....
abid
11-20-2011 02:18 AM
Dear Abid,
what you try to do will in this way not work without proper subnetting.
From my point of view all you can do is to hack your 192.168.1/24 network in pieces.
What here matters is the required different subnet mask.
e.g.
1 router, 2 FE, 2 Switches 2 PC.
you can do following:
on FE 0/0 assing a subnet with a length of 6 usable ip addresses, means:
192.168.1.0/29
conf t
interface FastEthernet 0/0
ip address 192.168.1.1 255.255.255.248
exit
interface FastEthernet 0/1
ip address 192.168.1.8 255.255.255.248
end
wr
copy run start
what here happen is a subnetting in which you take a part from a big net and section it to 2 x 8 IP addresses in which each has 6 usable addresses.
you can now assign to your first PC the IP: 192.168.1.2 Mask: 255.255.255.248 Gateway: 192.168.1.1 and
to your second PC: IP: 192.168.1.9 Mask: 255.255.255.248 Gateway: 192.168.1.8
I trust the above example clarifies the matter.
All the best!
David.
11-20-2011 02:26 AM
hey David,,
You are great...
thank you so much....
11-20-2011 02:32 AM
you are most welcome.
kindly vote the correct answers as it helps other users to keep track of the right tasks.
All the best!
David.
