Community Member
Simple Routing between 2 VLANS
Bridge BVI10 is setup with IP address of 10.10.20.1 subnet mask 255.255.255.0. VLAN10 is configured as a VLAN for IRB and part of the BVI10 bridge group.
Fast Ethernet Port 0 is assigned to this VLAN.
It also has its own DHCP Scope.
Bridge BVI20 is setup with IP address of 10.10.30.1 subnet mask 255.255.255.0 VLAN20 is configured as a VLAN for IRB and part of the BVI20 bridge group.
Fast Ethernet Port 1 is assigned to this VLAN>
A PC attached to FE0 can ping 10.10.20.1 and itself and the internet.
A PC attached to FE1 can ping 10.10.30.1 and itself and the internet.
I want the PC in FE0 to be able to ping the PC attached to FE1 i.e 10.10.30.1 (the other VLAN) but not the other way round.
Can someone advise how to modify the configuration to achieve this.
M.
Hall of Fame Super Bronze
Re: Simple Routing between 2 VLANS
You need to create an ACL on BVI10
access-list 101 deny icmp host 10.10.30.1 any echo
access-list 101 permit ip any any
interface BVI10
ip access-group 101 in
Community Member
thanks.
155
