Simple routing question
itfchadrob
I know this is quite simple, but the end result continues to elude me..
I have two LAN's, 192.168.0.0 (A) and 192.168.100.0 (B). I need the hosts on (B) to talk the servers on (A).
I have a Cisco 2801 Router. From (A) I can ping the interface configured to subnet (B) but cannot ping the hosts on the other side.
What is the simplest configuration for making A and B talk to each other efficiently? Thanks
16 Replies 16
Harold Ritter
Make sure you configure the default gateway (router local interface address) on the workstations.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Yep, have the router interface set as gateway, in addition to my LAN gateway...is this bad?
You should nornally have only one default gateway.
If you just want to test the connectivity between subnet A and B then you could just manually add the routes on the workstations as follow (assuming they are windows WS):
on workstations on subnet A:
route add 192.168.100.0 mask 255.255.255.0 192.168.0.9
on workstations on subnet B:
route add 192.168.0.0 mask 255.255.255.0 192.168.100.1
This should do what you are looking for.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Ive done this as well, still doesnt work. Perhaps I have something else wrong here...
dschuckman
Is it possible to see the configuration that you are using?
Yep...Im new to Cisco routers so this is a test environment...
Building configuration...
Current configuration : 1857 bytes
version 12.4
service config
hostname itfroute01
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$iH4t$INo3qB3/GCKlCHtjPH4JS/
enable password
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip routing
no ip cef
no ip dhcp use vrf connected
ip domain name itfnet.com
ip name-server 192.168.0.4
ip name-server 192.168.0.6
interface FastEthernet0/0
description $ETH-LAN$
ip address 192.168.0.9 255.255.255.0
ip access-group sdm_fastethernet0/0_in in
ip access-group oubound0/0 out
no ip route-cache
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
ip address 192.168.100.1 255.255.255.0
ip access-group sdm_fastethernet0/1_in in
ip access-group outbound0/1 out
ip nat inside
no ip route-cache
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 permanent
ip route 192.168.0.0 255.255.255.0 FastEthernet0/0
ip route 192.168.0.0 255.255.255.0 FastEthernet0/1
ip route 192.168.100.0 255.255.255.0 FastEthernet0/0
ip route 192.168.100.0 255.255.255.0 FastEthernet0/1
ip http server
ip nat inside source list sdm_fastethernet0/1_in interface FastEthernet0/0 overload
ip access-list standard oubound0/0
remark SDM_ACL Category=1
permit 0.0.0.0 255.255.255.0
ip access-list standard outbound0/1
ip access-list extended sdm_fastethernet0/0_in
permit ip any any
ip access-list extended sdm_fastethernet0/1_in
remark SDM_ACL Category=3
permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
password
login
end
For starters try taking all the following route statements out:
I think the next problem is in your outbound0/1 and outbound0/0 access-lists.
I am not sure what you actually want to permit out those interfaces but assuming you want to permit all traffic it needs to be
permit ip any any
if you just want to permit the specific subnet out each interface it would need to be for outbound0/0
permit 192.168.0.0 0.0.0.255
and for outbount0/1
permit 192.168.100.0 0.0.0.255
right now your access-list is only permitting network any.any.any.0 and nothing else.
Ok, here is my new config, still cant ping hosts on B...
Current configuration : 1612 bytes
version 12.4
service config
hostname itfroute01
boot-start-marker
boot-end-marker
no logging buffered
enable secret xxx
enable password
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
no ip routing
no ip cef
ip access-group any in
ip access-group any out
no ip route-cache
speed auto
full-duplex
no mop enabled
ip nat inside
no ip route-cache
duplex auto
speed auto
ip classless
ip http server
ip access-list standard any
permit any
permit ip any any
remark SDM_ACL Category=2
permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
password
login
end
I know this is simple stuff..
I can ping both router interfaces from both subnets, all routes are in the windows routing tables, but STIll cant ping hosts behind the router. errr
Thanks for all the help, very appreciated
can i see what the ACL's look like now
Standard IP access list any
10 permit any (4139 matches)
Standard IP access list oubound0/0
10 permit 0.0.0.0, wildcard bits 255.255.255.0
Standard IP access list outbound0/1
Extended IP access list sdm_fastethernet0/0_in
10 permit ip any any (124287 matches)
Extended IP access list sdm_fastethernet0/1_in
Your ACL is preventing this traffic from crossing the interface. The ACL's are affecting this.
Can you try to modify them the way I previously recomended. Or a quicker solution would just be to remove the oubound0/0 and oubound0/1 from the interfaces!!
You have a 'no ip routing' statement. Enable routing by doing an 'ip routing'.
--CS
