Simple SVI / Routed Interface scenario does not work
Photogregor
Hi everybody,
 I tried to setup a simple L2/L3 routing environment with switch and router, just for learning purpose. Please see attached screenshot for the topology. It does not work, I cannot figure out why. Both PC can ping each other and can ping L3-port on switch(192.168.0.1). From switch I can ping everything and from router as well. But what I cannot ping is from PC to routers IP addresses. I would expect to be able to ping both of them. What's wrong?
 Thanks for anyone to have a look at that,
Stefano
 Excerpts from the configs:
Config on Switch 3650:
 ip routing
interface GigabitEthernet1/0/1
 switchport access vlan 10
interface GigabitEthernet1/0/2
 switchport access vlan 20
interface GigabitEthernet1/0/24
 no switchport
 ip address 192.168.0.1 255.255.255.248
interface Vlan10
 ip address 10.1.1.1 255.0.0.0
interface Vlan20
 ip address 10.2.2.1 255.0.0.0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet1/0/24
Config on Router 2911:
 interface GigabitEthernet0/0
 ip address 192.168.0.2 255.255.255.248
interface GigabitEthernet0/1
 ip address 99.0.0.1 255.0.0.0
interface GigabitEthernet0/2
 no ip address
 shutdown
ip route 0.0.0.0 0.0.0.0 99.0.0.2
PCs are in 10.x.x.x/8 network.
Switch (3650) is configured as a router ("IP routing" enabled).
Router (2911) is connected on one side with the switch on 192.168.0.2/29 network.
PC <--> SW (Layer 3 SW) <--> Router.
You can not ping from PCs to the 2911 router. The reason is there is no route from the router back to the PCs in the router RIB (run "show ip route"). You can simply fix this by adding a static route in the router:
ip route 10.1.1.0 255.0.0.0 192.168.0.1
ip route 10.2.2.0 255.0.0.0 192.168.0.1
HTH,
Meheretab
HTH,
Meheretab
HTH,
Meheretab
HTH,
Meheretab
Predrag Jovic
Level 3
Level 3
Route on 2911 is missing (as meheretabm said, but just one route is missing)
ip route 10.0.0.0 255.0.0.0 192.168.0.1
However:
interface Vlan10
interface Vlan20
Should not be allowed on device (at least with both interfaces active) since network IP address ranges overlap.
Photogregor
Hi Meheretab, hi Predrag,
thanks to both of you. Backwards routes where missing, now it works. And yes, the subnet mask for SVI addresses was wrong in my posting, on the switch it was correct (255.255.255.0).
Sorry for creating efforts, should have seen that myself.
Regards, Stefano
