10-22-2008 03:53 AM - edited 03-06-2019 02:04 AM
We have two buildings beyond 200 metres.We have got single mode fibre running between the buildings but we have GLC-SX-MM= SFP module in hands.CAn we do the connectivity ?If works,is it a standard pratise ?
10-22-2008 05:38 AM
Here is a link that shows where you can mix MM with SM and if a conditioning patch cord is needed (refer to Table 6).
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/gbic_sfp_modules_install/5067g.html
Hope that helps.
10-22-2008 05:43 AM
Hello Sivakumar,
it doesn't work :
SM fiber acts as a narrower filter and will drop most of optical energy of the MM transmitter.
You need SM GBICs or SFPs to use SM fiber
Hope to help
Giuseppe
11-14-2008 05:29 AM
Thanks for your reply.
thanks siva
