11-03-2014 01:06 AM - edited 03-07-2019 09:21 PM
We are having some problem.We have Dell servers with win2008r2.Teaming configured with these servers.Previously all teamed port were connected to single switch.That time no issue.But I have shifted one port to another switch for redundancy .After that all the servers became very slow .Anybody faced this issue.
Solved! Go to Solution.
11-03-2014 05:03 AM
If You have normal ethernet switches this will not work if the servers are configured for active/active, because the mac-address of the server will flap between the switches.
If You want to have redundancy, You have to configure the server for active/standby (active/passive), so only one link at the time is active.
If You wont both links to be active You have to connect to something that can handle active/ative links, such as nexus switches or a pair of vss switches or a switchstack.
/Mikael
11-03-2014 05:03 AM
/Mikael
11-19-2014 09:16 PM
My problem solved after I put both active ports in same switch ....
11-04-2014 03:53 AM
Can you confirm which teaming option you have selected within the Dell config?
Were you using a portchannel beforehand?
