Small Business Setup Recommendation
Hi There,
I have a client with 12 pcs running of a server with win 2008 using it as a file and database server. All but 2 clients are running on gigabit and I would like a gigabit capable device.
What would you guys recommend? They are currently using a Netgear GS716 (http://www.netgear.co.uk/gigabit_smartswitch_gs716t.php) which I believe is not functioning correctly.
I was looking at the SLM2024-G5 - will it cut it? I dont want any problems and want no speed/delay issues.
Thanks in advance!
1 REPLY
Gold
Re: Small Business Setup Recommendation
Do you need managed or unmanaged?
THere is a 16 port Gig switch thats pretty low priced
SG-100-16
here is a link to one line of cisco small business hardware.
http://www.cisco.com/cisco/web/solutions/small_business/products/routers_switches/100_series_switches/index.html-tab-Models
1484
