Webcast-Catalyst9k
Small network with 2 router and 42 layer 2 switches
I have 2 router with 2 WIC 2 T & HWIC 4 T
1st router will connect to 2 deferent ISP with connection 6 m to support customer to access the web server
2nd router will connect to 2 deferent ISP with connection 8 m
To support the customer to access web server>>>>>>>>>>>>>>>>>.
I need to know if I configure VTP domain I need to know the maximum support client switches in this VTP domain >>>>>
1-I need to make load balance between to router
2- I need at lest 12 m to customer to access the web server
3- I need 2 m for user in internal network to can reache the internet
4- I need to configure 10 VLAN
I need solution for configuration
1 REPLY
Silver
Re: Small network with 2 router and 42 layer 2 switches
Load balancing are being different way as per which protocol you are using in your routing. Here is the some URL which will help you for load balancing purpose:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml#topic1
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml
For the configuration VLAN follow the URl:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_configuration_example09186a008009478e.shtml
105
