Resolved! vmware nic teaming
Hi, if NIC are teamed on VMWARE and set to "route based on the orginating virtual id" do i need to port-channel on the cisco switch ?
The content you are looking for has been archived. View related content below.
There's two network monitoring accounts that constantly log in and out of my devices, and it's making it difficult to use logs to troubleshoot issues because the logs are totally clogged up with useless messages. I looked at the forums on how to drop...
Guys I am trying to determine what the difference between "full poe" and "poe"I am replacing a few WS-C3560G-48PS-S switches at my clients and need to make sure I am providing them with the same PoE functionality that they currently have with the WS-...
I think I already know the answer to this.Will an SFP-10G-SR work in the 4G model if the interface is set to 'speed 1000' ?It currently keeps err-disabling in the 9200, even with speed at 1000I have a 9200 connected to a CBS350 (which I am sure will ...
Hello,I have a question, so far I have only ever upgraded to the next or higher version. Now the planis to downgrade because there are connection interruptions. FYI, it is a stack of 2 3650-48PDswitches. Almost nothing is configured there except that...
Hi, I have two WS- c3750x-48T -L switches stacked - connected back to back with Stack cable. Now one of the switch failed and I have only WS- c3750X- 12 S stackable switch as SPARE with me. So can replace 48 Port with 12 Port ? Does it need an...
sw# show system resourcesLoad average: 1 minute: 0.33 5 minutes: 0.38 15 minutes: 0.31Processes : 576 total, 1 runningCPU states : 0.25% user, 1.00% kernel, 98.74% idle CPU0 states : 0.00% user, 0.00% kernel, 10...
Is there a better way to upgrade these yet?Obviously, I want to reboot after-hours. The install command still cannot be scheduled.install add file flash:cat9k_iosxe.17.09.05.SPA.bin activate commit prompt-level noneIf I do not do prompt-level none th...
Hi, can anyone please advise whether SFP+ cisco SFP-10G-T-X can be used on cisco 3850 network module? thanks in advance!
Greetings,On an international L2 VPN service, the customer is complaining about latency.Here are several ping tests on the 2 PE routers:RouterA#ping mpls pseudowire b.b.b.b vcid source a.a.a.a repeat nSuccess rate is 100 percent (100/100), round-trip...
1Gb catalyst switches has air intake from front and side and exhaust to the back. And no versions with reverse-airflow.I know many places where such switches installed port side to the hot corridor - so it intake hot air and blow to direction of col...
Hi all, I have a 3650 stuck in the switch prompt. I've tried to set the IP address using the below commands so that I can upload the IOS, but I am unable to. set IP_ADDR Set DEFAULT_ROUTERbelow is the file system outputswitch: dirList of filesystems ...
Hello,I have a Nexus 9K trunked to a C9200LOn the Nexus 9K the port is:interface Ethernet1/19switchportswitchport mode trunkswitchport trunk native vlan 888switchport trunk allowed vlan 1,254,995no shutdownOn the C9200L the port is:interface TenGigab...
Hi - I have a general question about where to find the official Cisco document for the Cisco Nexus 9300 ports and services requirements document?Thank You
I need to clarify if my Switch sg220-26 has POE ports. The documentation is confusing and I CANNOT see the POE Option for Port Management by entering as Switch Administrator.Otherwise, it is possible to make this Switch POE by placing some external s...
Subject | Author | Posted |
04-23-2024 02:53 AM | ||
04-19-2024 05:58 AM | ||
04-17-2024 03:50 AM | ||
04-15-2024 06:06 PM | ||
04-12-2024 05:48 AM |
User | Count |
11 | |
10 | |
8 | |
7 | |
6 |
