Webcast-Catalyst9k
SMI routing protocols that converge rapidly
HSRP - Does the Standard Multilayer Image provide a routing protocol that can converge as rapid or near rapid (10/20ms) as when using EIGRP and HSRP together...Basically, is the Enhanced Mutilayer Image the best choice for achieving the fastest fault tolerant recovery times?
1 REPLY
Purple
Re: SMI routing protocols that converge rapidly
I believe standard only supports RIP,EIGRP stub and static routing . If you need ospf and standard eigrp then you need Enhanced.
121
