Community Member
SNMP configs....
Hi all,
Kindly let me know what all SNMP commands are useful for typical 6500 series swicth used in datacenter. I wish to configure this switch for sendinig SNMP alerts in case of 'module down' or 'module power down', but I do not want to monitor the link down/up of each and every switchport (just want to monitor modules). Kindly let me know how can it be done?
thanks and regards,
--Gaurav
Re: SNMP configs....
Try these
snmp-server enable traps snmp authentication coldstart warmstart
snmp-server enable traps chassis
snmp-server enable traps module
snmp-server enable traps event-manager
snmp-server enable traps hsrp
snmp-server enable traps rtr
snmp-server enable traps entity
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server host xxx.xxx.xxx.xxx
These cover you module up and down
Community Member
Thanks there...!
Kindly let me know what all MIB's are required to be downloaded for these SNMP-options....? We will be using netcool and HP-NNM for SNMP monitoring.
Thanks and regards,
--Gaurav
Hall of Fame Super Gold
May I be allowed to add the following:
snmp-server enable traps cpu
snmp-server enable traps transceiver
snmp-server enable traps power-ethernet
To disable logging of links going down/up, go to each interface and configure the following:
no logging event link-status
no snmp trap link-status
Community Member
Thanks...
Kindly let me know if I need to download MIB's from cisco.com in order to monitor these parameters using HP-NNM and netcool. If yes, what all MIB's should be used....
Thanks and regards,
--Gaurav
193
