SNMP on Cisco 3560
Hey,
I have a network of 300+ nodes and I have started using SolarWind LAN Surveyor for the management of my PC's and Switch for that i have enabled SNMP on Cisco 3560 Switch but when i try scan my network through software than it only shows me Switch Name and IP only. As i want to gather other informations as well like
1. Which system is connected on ports
2. To which VLAN the ports are mapped to
3. System IP Address / Hostname
can i gather these information with SNMP and how can i conifigure it means what trap should i be using for this.
SNMP on Cisco 3560
First thing to configure the device in SolarWinds you need to know the device IP and its SNMP string first.
With the SNMP based monitoring tool like SolarWinds, you can get the device info like all ports info like description of ports (you may put description like to which device the port connected) and CPU & Mem utilization of the switch and bandwidth utilization on the specific port.
And also network latency you will get.
I dont think that SolarWinds will porvide the mapped VLAN infor.
Please rate all the helpfull posts.
Naidu.
SNMP on Cisco 3560
I have already configured SNMP through these commands
snmp-server enable traps
snmp-server host 10.10.5.2 public
snmp-server community public ro
but when i see show run then it shows me all these commands running
snmp-server community public RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps cluster
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon
snmp-server enable traps mac-notification
snmp-server enable traps copy-config
snmp-server enable traps config
snmp-server enable traps hsrp
snmp-server enable traps rtr
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
what else need to be done
SNMP on Cisco 3560
Actually you no need to have that much config to manage the device in SolarWinds with its SNMP string.
I have the only following command configured in my 3560 switch and able to manage in SolarWinds.
snmp-server community ABC RO SNMP_ACCESS
ip access-list standard SNMP_ACCESS
permit 10.30.30.2
permit 10.40.20.10
Naidu.
SNMP on Cisco 3560
with these commands i am only able to see the switch but not its connected ports means which port is connected to which machine.
permit 10.10.5.2
SNMP on Cisco 3560
Strane you should be able to see the connected ports and all.
You can follow the below steps....
1. Configure the switch with its IP and snmp in Solar.
2. Go to the device in Solar -->right click on the device -->go to node detaill -->list resources, here one window will open in that you should see all the switch interfaces.
Now you can select which interface you want monitor by solar by check.
Naidu.
SNMP on Cisco 3560
please see the attached screen shot.
my switch is configured with an IP Address and i didnt find any devices menu in LANSurveyour
2134
