01-23-2009 07:02 AM - edited 03-06-2019 03:36 AM
i have some confusion with SNMP:
snmp-server host 1.1.1.1 communityname eigrp bgp
That command would send snmp traps (EIGRP and BGP) to snmp server 1.1.1.1 with the community name of community name correct?
which then confuses me about the following commands:
snmp-server community communityname ro
snmp-server community communityname rw
I assume those would be to change what that particular community can do?
Another confusion is:
snmp-server enable traps eigrp bgp
Does this have to be enable to enable those particular traps?
Solved! Go to Solution.
01-23-2009 07:26 AM
Hi Mike,
snmp-server host allows you to specify to who you want to send the traps. But first you need to enable Trap generation with the snmp-server enable traps command. Then you have the option in the snmp-server host command to limit which traps must be send to which host.
On the other hand snmp-server community is there to filter SNMP request coming from your NMS.
You will find mode infos here:
http://www.cisco.com/en/US/docs/ios/12_3/configfun/command/reference/cfr_1g11.html#wp1028282
Laurent.
01-23-2009 07:26 AM
Hi Mike,
Laurent.
01-23-2009 07:44 AM
Ahh okey
So you enable the traps #1
The snmp-server host will allow you to send different traps to different servers
Very clear now.
Thank you.
