Community Member
snmp traps
Hi all, would it be possible to get my router to send an snmp trap when the isdn layer 1 status is down, is there a general setting that will enable all traps, ie snmp-server enable traps ?
Re: snmp traps
Hi Carl
The command :-
snmp-server enable traps linkdown linkup
Should pick this up. You can disable this on an individual interface level with the interface level command :-
no snmp trap link-status
I assume that you have the needed SNMP settings already configured ie
snmp-server host x.x.x.x
snmp-server community RO
logging trap (debugging is useful)
Community Member
Re: snmp traps
how would i get it to send all snmp traps? woudl i just do snmp server enable traps ?
142
