Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
software to monitor server vs network
Hi all, is there any software that can do this, ie prove to someone it is a server issues not a network issue?
Re: software to monitor server vs network
Which particular problem?
for example users are moaning the web server is running slow, i want to monitor response time from server vs network
First, you should be monitoring port bandwidth utilization and errors, cpu and memory utilization of all network devices plus logging into a syslog server so that you have historical data to work with whenever theres a network problem occur.
After checking from your network monitoring tools that network is not the bottleneck, then you can show and justify to everybody specially the server admin that network is not the bottleneck. It's common to people to point to the network as the culprit whenever the connection is slow or something is not accessible. You need to provide proof to prove otherwise. Take note that throughput is first controlled in the application level.
For my case, I monitor from switch, router, firewall, load balancer, server, web, dns, ldap, radius, smtp, mail, ftp, even the monitoring tools. I monitor the following; bandwidth, cpu, memory, swap/page file, disk/partition, routing, uptime/downtime, latency, interface errors, services, login, etc.. that's why when something wrong happens, I'm able to quickly find the root cause or the source of the problem.
can you tell me what tools you use for this ?
cheers
You can use MRTG, for the uptime/downtime there are many commercial software like WhatsUp and Big Brother. Kiwi for syslog
134
