07-12-2014 05:33 AM - edited 03-07-2019 08:02 PM
I am trying to configure WCCP on Cisco3750G-48PS switches. But one of the Cisco command " ip wccp 53 redirect in" is not accepting on Gig interface. I have tried it by uploading latest IOS image and also tried with different featuresets.
Can someone help me if it can be achieved.
MAC
07-12-2014 08:39 AM
What is the error message when you enter the command?
What is the output of "ip wccp 53 redirect ?" ?
Also, what is your license level? "sh license"
07-12-2014 09:49 AM
I am configuring the below commands
interface GigabitEthernet 1/0/47
It says
Switch(config)#interface Vlan11
Switch(config)#ip wccp redirect exclude in
% Invalid input detected at '^' marker.
Switch(config-if)#ip wccp 53 redirect in
% Invalid access list name.
MAC
07-12-2014 02:06 PM
What is your license level?
Can you provide sh license and sh version?
07-12-2014 11:43 PM
07-13-2014 09:34 AM
Your version should support WCCP. Also, you have the correct license/image.
Can you try following this document and config WCCP?
This is for 12.2(55), but should also work for your version.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/configuration/guide/scg3750/swwccp.html
07-14-2014 12:47 AM
Thanks for your input, so ip wccp redirect in command doesn't support in 3750 switches and instead we have configure it as web cache service and use the command ip wccp web-cache redirect in right?
MAC
