some ports are not working in cisco 2960 switch
some ports are not working in cisco 2960 switch suddenly.The tdr results for all the ports show same results.
GF_TEL_NEW2_175#sh cable-diagnostics tdr int fa 0/6
TDR test last run on: March 01 22:41:45
Interface Speed Local pair Pair length        Remote pair Pair status
Fa0/6     auto  Pair A     1    +/- 1  meters N/A         Open
                Pair B     0    +/- 1  meters N/A         Short
                Pair C     N/A                N/A         Not Supported
                Pair D     N/A                N/A         Not Supported
GF_TEL_NEW2_175#sh cable-diagnostics tdr int fa 0/7
TDR test last run on: March 01 22:49:26
Fa0/7     auto  Pair A     1    +/- 1  meters N/A         Open
GF_TEL_NEW2_175#sh cable-diagnostics tdr int fa 0/21
TDR test last run on: March 01 22:40:53
Fa0/21    10M   Pair A     N/A                N/A         Normal
GF_TEL_NEW2_175#sh cable-diagnostics tdr int fa 0/22
TDR test last run on: March 01 22:41:34
Fa0/22    auto  Pair A     9    +/- 1  meters N/A         Open
pl.give solution to solve the problem.
with regards
netteamicf
Cabling issue?  Try
Cabling issue?  Try connecting these ports with a new patch cable directly to a PC - bypass all of the internal wiring and re-test.
Hall of Fame Super Gold
TDR shows you've got cabling
TDR shows you've got cabling issues.  For FastEthernet, you need both Pair A and Pair B to be "Normal".  If you have results like "Open" or "Short", it's not good.
Cable distance shows the cable directly connected to the ports are faulty.
77
