Sonicwall NSA 2400, SonicPoint N, Cisco SFE2010P
     I have a sonic wall nsa 2400, a sonic point N, and a cisco SFE 2010P. I am having issues getting the VLAN to work with my Guest SSID. My plan is to use interface X4 for internal wifi, and X4:100 (vlan) for the Guest WiFi. NSA2400 (X4) --> RJ45 --> SFE2010P (Port1) --> RJ45 --> SP1 (Port2, Port3) I hoep this makes sense. SFE2010P is connected to the X4 interface of the NSA2400 through Port 1 (SFE2010P), and Port2, and Port3 have a SonicPoint connected to them.
     Configuration:
          NSA 2400
               X4 - 10.0.24.1
               X4:100 - 10.0.25.1 (VLAN)
               SSID Guest linked to X4:100   ***** ISSUES CANT CONNECT
               SSID Private linked to X4   *** WORKS FINE.
          SFE2010P - Layer 3 mode
               Adde VLAN 100
               Port 1 mode is set to trunk
               VLAN to Port config for e1 is set to 1U,100T
          ALSO DHCP is being handled by a Windows Server located at 10.0.20.7 (which both networks(x4, x4:100) have access to)
     I am only having issues connecting to the Guest SSID located under VLAN100.
     I am assuming I am missing something related to the VLAN either at switch or the DHCP settings. Can anyone help?
Andre
  • LAN Switching and Routing
Everyone's tags (6)
1 REPLY
Just figured it out, forgot to trunk and group port 2 and port3. all set now.
1257
