sp rommon boot variable settings
Dear Pros,
I need your help on the below issues asap.
I am in 6509 SPrommon mode.
in entering set cmd i can see 3 items as
boot=
BOOT=
BOOTLDR=
I entred
BOOT=slot0:c6sup11-jsv-mz.121-26.E3
BOOTLDR=slot0:c6msfc-boot-mz.121-26.E3.bin
then reset
I am getting error message as below
can not .... boot bootflash:
I want to remove the word boot from the set output.
How can i do that?
I want to boot using BOOT=cmd
swamy
Blue
Re: sp rommon boot variable settings
you cannot remove the bootldr from bootflash: if you are using a sup1 and msfc1.
(the bootldr must reside on the bootflash: if you use the sup1/msfc1)
also, if one of the variables is empty, it will show as BOOT= for example.
please see the following link for more info on 6500 IOS boot configuration:
http://cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007e721.html#wp1022904
gPULOS,
Now the sup boot normal.
All the 4 LEDS are green. (status, system,active,pwr mgmt) but whenever i inserted the second standby sup1A to the slot 2 of the chassis it boot the image and finally it showing the below console message goes to "router-sdby> mode.
press return to get started
00:01:29: %sys-stdby-5-restart:system restarted- -
00:01:29:%snmp-stdby-5-coldstart:snmp agent on host router is undergoing a cold start
Please what could be the workaround to solve the problem.
Please help me since it is very urgent issue to resolve to one of my corporate customer.
Thanks in advance
swamy
Silver
Hi Swamy ,
Can you attach log which has the messages.
Are you seeing only two messages ?
Satish
Hi Swamy,
In rommon mode, try
roomon1>BOOT:=sup-slot0:
rommon2> sync
rommon3>boot
Let us know how it goes.
regards,
-amit singh
430
