Community Member
SPAN config - Difficulty seeing 802.1q tagging ?
Well I am definitely a bit frustrated with this one.
My setup is a Catalyst (3560 C3560-IPBASE-M), Version 12.2(35)SE5,
I have a cisco phone with a PC behind it on port gi 0/40
     port config
                    switchport access vlan 5
                    switchport voice vlan 105
Phone gets 105.x ip and PC gets 5.x ip. All is working well.
I am trying to sniff this traffic to ensure vlan tagging and QOS markings by using SPAN.
monitor session 1 source int gi 0/40
monitor session 1 destination int gi 0/3 encapsulation replicate
Can someone confirm that this is the correct config for this ?
Wireshark shows me entire phone conversation but I cannot see any 802.1q tagging..
I also tried to sniff int gi 0/49 as it is my dot1q trunk back to the core and I still cant see any vlan tagging..
Hoping someone can help me out on this one. I have read thru the docs and this should be a easy...
Community Member
Re: SPAN config - Difficulty seeing 802.1q tagging ?
Found the cause, it appears that the Nic driver and XP was stripping off the 802.1q info.
I ended up having to add a line in the registry under the NIC card settings.
Hall of Fame Super Silver
Hello Dave,
we had a similar issue some time ago getting different results with different laptops.
A useful explanation of how to capture vlan tags with wireshark is reported here:
It provides the methods to override the vlan tag stripping on windows based PCs (that are different depending on the NIC vendor)
Hope to help
