Community Member
SPAN on 4500 and 6500 series switch
I have some 200 servers connected to my L3 switch. I am planning to SPAN for every server to one Sniffer. Is it technically viable? what are the possible challenges I might face ?
Thanks in advance..
Re: SPAN on 4500 and 6500 series switch
Where is the SPAN destination located. Are you planning to do a local SPAN or a remote SPAN. SPAN is done in hardware so you can do it. You might just be hiiting the hardware limitation on the switch. With Local SPAN, you can create only 2 sessions and a maxiumum of 128 SPAN sources with Release 12.2(18)SXE and later.
Please read the doc below for all the restrictions before going ahead :
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/span.html#wp1102614
HTH,
-amit singh
Community Member
I am planning for Local SPan. If I do a Source SPAN with VLAN, inderectly covering all the ports, whether still I have hardware limitation......
Should not be a problem. But again it depends on the hardware how it behaves with such a huge traffic. As it is done in hardware, we beleive that you will be absolutely fine with it.
Community Member
I will test my luck...
thanks for the data..
251
