SPAN port on distribution 6500 VSS
habeebuddin786
Hello folks,
We would like to capture the traffic from the access switch 4510 on security appliance which has sniffer installed. It has 10G ports on it. I tried configuring on distribution 6500 VSS to capture the traffic from the access switch 4510 but nothing has observed. Its weird to notice that the security appliance is receiving the packets but not seeing any data capture.
Distribution switch 6500 VSS port Te1/2/13 is configured for security appliance:
int Te1/2/13
description sniffer (monitoring)
switchport
no shut
sh int Te1/2/13 observed the interface is up up in default vlan 1.
Run the following commad to capture the traffic. Source interface is downlinks to access switch (4510), in this case its Te1/2/3 and Te2/2/3 is configured as etherchannel 7.
6500-dist-vss(config)#monitor session 1 source interface te1/2/3 both  ------------------------> Tried giving one interface of access-switch 4510 but doesn't take it as its a member of port-channel7
% Etherchannel member(s) Te1/2/3 cannot be monitor source
6500-dist-vss(config)#monitor session 1 source interface po 7 both  -----------------------------> given both after port-channel 7
6500-dist-vss(config)#monitor session 1 des
6500-dist-vss(config)#monitor session 1 destination inter te 1/2/13
6500-dist-vss#sh monitor session 1
Session 1
Type                   : Local Session
Source Ports           :
    Both               : Po7
Destination Ports      : Te1/2/13
Egress SPAN Replication State:
Operational mode       : Centralized
Configured mode        : Centralized (default)
6500-dist-vss#sh int Te1/2/13
TenGigabitEthernet1/2/13 is up, line protocol is down (monitoring)
  Hardware is C6k 10000Mb 802.3, address is 649e.f3a5.5d44 (bia 649e.f3a5.5d44)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s
  Transport mode LAN (10GBASE-R, 10.3125Gb/s), media type is 10Gbase-LR
  input flow-control is on, output flow-control is off
  Clock mode is auto
  Last input never, output 00:00:22, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 986000 bits/sec, 184 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     56724 packets output, 38271128 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
6500-dist-vss#
6500-dist-vss(config)#monitor session 1 source int po7 rx --------------------------------> Tried giving Receive at port-channel 7 from access switch 4510
6500-dist-vss(config)#monitor session 1 destination interface Te1/2/13
6500-dist-vss(config)#^Z
% Incomplete command.
Session 1
Source Ports           :
    RX Only            : Po7
  Full-duplex, 10Gb/s
  Clock mode is auto
  Last input never, output 00:10:06, output hang never
  5 minute output rate 3854000 bits/sec, 1008 packets/sec
     3523947 packets output, 2309711951 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
I thought since portchannel7 is 20 Gig and destination interface is 10Gig this might causing some issue or some bottleneck so I tried changing the source interface from po7 to te1/5/5 which is uplink to core 6500 and  this link is not member of port channel and its 10Gig:
6500-dist-vss(config)#monitor session 1 source int te 1/5/5 tx
6500-dist-vss(config)#monitor session 1 destination int te1/2/13 ?
  ,        Specify another range of interfaces
  -        Specify a range of interfaces
  ingress  Enable ingress traffic forwarding
  <cr>
Session 1
Source Ports           :
    TX Only            : Te1/5/5
But still no luck, the issue remains. Is something I am missing configuring the distination port. Kindly suggest.
-Ahmed
walter baziuk
Level 5
Level 5
i have the same issue!!!!
any soln yet
Kevin Dorrell
Level 10
Level 10
"Its weird to notice that the security appliance is receiving the packets but not seeing any data capture."
I remember seeing somethig like this once.  It turned out the traffic I was trying to capture was dot1q tagged, and the NIC of my capture device was discarding it 'cos it wasn't expecting to see the tag.  I cannot remember how I overcame the problem, but it was something to do with the NIC driver in the capture device.
