Community Member
SPAN session question on two 6509s
I have two 6509 switch connected via a fiber trunk on the SUP blade.
All vlans are trunked on this trunk.
Both switches have monitor sessions set up on them and I am getting an error trying to create an additional one.
I am thinking I can remove one of them cecause it looks redundant to me:
Switch 1
monitor session 1 source vlan 1 , 5 , 10 - 249
monitor session 1 destination remote vlan 998
monitor session 3 source vlan 250
monitor session 3 destination remote vlan 251
Switch 2
monitor session 1 source vlan 1 , 10 - 249 rx
monitor session 1 destination interface Gi8/40
monitor session 2 source interface Gi8/19
monitor session 2 destination interface Fa4/40
monitor session 6 destination interface Gi8/21
monitor session 6 source remote vlan 251
If switch 2 is monitoring all vlans and is detined for port g8/40, this should collect all information on both switches if all vlans are trunked, correct?
This means I could remove monitor session 1 on switch one (detined for vlan 998) because this would be collected on the other monitor session, correct?
Also, I do not see any ports in vlan 998, how would I collect anything from that monitor session?
Hall of Fame Super Silver
Re: SPAN session question on two 6509s
Hello Richard,
both vlans 251 and 998 are remote span vlans.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/span.html#wp1059942
but probably vlan 998 is not used anymore
verify with sh vlan id 998 on Switch1
Hope to help
Giuseppe
Community Member
Correct,
But is my thinking correct also in that since I am spanning the vlans on switch 2 and all vlans are trunked, the remote span on switch 1 to vlan 998 is redundant?
Is that correct?
Also, on my destination port, does this have to be in any particulr vlan?
For example if it is a workstation that will be collecting, the destination port needs to be in the workstation vlan?
Hello Richard,
the destination port doesn't need to be in the remote span vlan.
the remote span vlan is a logical pipe to carry captured traffic using the remote span vlan vlan-id on trunk ports from source switch to destination switch.
on destination switch the remote span vlan is declared the source of the monitor session and so it can be associated to a port that doesn't need to be in the rspan vlan.
Hope to help
Giuseppe
169
