Spanning Tree BPDU Guard Question
Once you have enabled spanning tree bpdu guard on a Cisco switch, how do you disable it? I researched the command and there doesn't seem to be a no spanning-tree portfast bpduguard.
Re: Spanning Tree BPDU Guard Question
"no spanning-tree bpduguard"
"spanning-tree bpduguard disable"
Globally you can use
"no spanning-tree portfast bpduguard default"
HTH..rate if helpful...
Thanks!!
Globally for all interfaces "spanning-tree portfast bpduguard default" will enable for all interfaces...
1170
