Spanning-Tree help needed
mrshabbs
Hi all, I have 4 switches  (2 x 2960 & 2 x 3500) connected together in 1 big loop (1 to 2 to 3 to 4) using fibre on the gigabit interface ports. My question relates to spanning-tree.
Switch 1 is the root bridge. Between switch 1 and switch4  i cannot establish lights on the interfaces g 0/1 (these interfaces are directly connected with fibre). Below is the output from both switches:-
switch1#show spanning-tree interface g 0/1
no spanning tree info available for GigabitEthernet0/1
switch4#
Interface Gi0/1 (port 40) in Spanning tree 1 is down
  Port path cost 4, Port priority 128
  Designated root has priority 24577, address d824.bd16.b500
  Designated bridge has priority 32768, address 0006.2828.d180
  Designated port is 40, path cost 12
  Timers: message age 0, forward delay 0, hold 0
  BPDU: sent 3, received 667
I would have thought one interface (int g 0/1 on switch 1 or switch4) would be in block status and the other remaining interface to be in fwd status. However as you can see from the above output there is no spanning-tree info available on switch1. On switch4 the interface is showing as down, which indicates there is no physical connection? I have replaced the fibre lead and the gbic modules in sw1 & sw4.
The result here is I have no redundant link (there is already a break between switch1 & switch4 becuase of this issue)
Can anyone shed any light on this please
8 Replies 8
jan.janovic.sk
Hi Shane,
I dont exactly know how to solve your problem, just wondering - if SW1 is root and is directly connected to SW4, you should expect Gi0/1 on SW1 to be designated - FWD state, but at SW4 Gi0/1 will be root port, so in FWD state too (not blocked). Correct me somebody if I am wrong.
Have you tried to change fiber to classical cross-over cable? Maybe it would also help to look in output of show int gi0/1 at both switches while they are connected and expected to work. Do these interterfaces work well in general?
Best Regards
Jan Janovic
Thanks for the reply Jan. I have checked the interfaces g 0/1 on switch1 and also switch4 as suggested, both are showing as down. I have replaced switch4, replaced the fibre connecting switch 1 and switch4 and replaced both gbics used on the interfaces g 0/1 of switch 1 & switch4. Interface g 0/2 on switch1 (connected to switch2) is DESG fwd.
Hello Shane,
Jan is heading in the correct direction - the up/down status of your ports is something that precedes STP, and is related to basic Layer1/Layer2 connectivity. If your ports are reported as down then they basically tell you they are disconnected - not blocked by STP.
Can you please post the complete output of the following commands from both Sw1 and Sw4?
  • show interface gi0/1
  • show interface status | inc Gi0/1
  • show interface gi0/1 capabilities
  • show run int gi0/1
Thank you!
Best regards,
Peter
Hello Peter, thanks for the reply. Please see below the outputs of sw1 and sw4 as suggested. On sw4 (3500xl) the cmd "show interface gi0/1 capabilities" is not allowed
SWITCH1#show interface gi0/1
GigabitEthernet0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is d824.bd16.b519 (bia d824.bd16.b519)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 21w6d, output 21w6d, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     66734 packets input, 12311737 bytes, 0 no buffer
     Received 3894 broadcasts (1799 multicasts)
     14 runts, 0 giants, 0 throttles
     14 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1799 multicast, 0 pause input
     168878 packets output, 42300964 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
SWITCH1#show interface status | inc Gi0/1
Gi0/1                        notconnect   1            auto   auto 1000BaseSX SFP
SWITCH1#show interface gi0/1 capabilities
GigabitEthernet0/1
  Model:                 WS-C2960-24PC-L
  Type:                  1000BaseSX SFP
  Speed:                 1000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),
                         tx-(4q3t) (3t: Two configurable values and one fixed.)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
  Multiple Media Types:  rj45, sfp, auto-select
SWITCH1#show run int gi0/1
Building configuration...
Current configuration : 36 bytes
interface GigabitEthernet0/1
end
switch4#show interface gi0/1
  Hardware is Gigabit Ethernet, address is 0006.2828.d199 (bia 0006.2828.d199)
  MTU 1500 bytes, BW 0 Kbit, DLY 0 usec,
  Keepalive not set
  Auto-duplex , 1000Mb/s, media type is SX
  output flow-control is off, input flow-control is off
  Last input 16:19:14, output 16:19:59, output hang never
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
     2584 packets input, 309915 bytes, 0 no buffer
     Received 2536 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 1702 multicast, 0 pause input
     68 packets output, 12336 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
switch4#show interface status | inc Gi0/1
Gi0/1                      notconnect   1          Auto    1000 1000BASESX
switch4#show interface gi0/1 capabilities
% Invalid input detected at '^' marker.
switch4#show interface gi0/1  ?
  accounting      Show interface accounting
  crb             Show interface routing/bridging info
  ethernet        Show ethernet vlan type
  fair-queue      Show interface Weighted Fair Queueing (WFQ) info
  flow-control    Show flow control information
  irb             Show interface routing/bridging info
  link-trap       Show interface traps on no link
  mac-accounting  Show interface MAC accounting info
  precedence      Show interface precedence accounting info
  pruning         Show interface pruning information
  random-detect   Show interface Weighted Random Early Detection (WRED) info
  rate-limit      Show interface rate-limit info
  status          Show interface line status
  switchport      L2 interface information
  trbrf           Show BRF tokenring vlan type
  type            Show vlan types
  |               Output modifiers
switch4#show run int gi0/1
Current configuration:
end
Hello Shane,
Thank you for the reply. The output you have posted suggests that there is a basic connectivity problem between your two switches.
The most natural question is whether the fiber and the optical GBICs/SFPs are okay and properly matched. Are you able to verify that each GBIC/SFP is capable of linking up successfully with some other GBIC/SFP that is proved to work? If these modules are using two fibers, you could make a test with looping the GBIC/SFP by interconnecting its Tx and Rx port, however, I recommend caution here - a longer fiber or an attenuator is recommended in order not to overload the Rx detector.
Also, the 1000BaseSX needs multimode fiber to be used - I assume you are using the proper fiber type.
Best regards,
Peter
Hi Paul
If I swap the 'suspect' fibre, gbic & sfp between sw1 & sw4 with the 'working' fibre, gbic & sfp between sw2 & sw3, the fault remains between sw1 & sw4. The connection between sw2 & sw3 becomes active. This proves there is no fault with the fibre, gbic or sfp. I agree there is a basic layer1 / 2 connectivity issue from the output of the interfaces however I believe I have confimed all hw as working. I will do further testing and keep you updated. Thanks for your help so far
Hello Shane,
You're welcome but the "thank you" you gave me is not deserved yet.
As the fault seems to be stuck between Sw1 and Sw4, I am starting to wonder if the SFP/GBIC slot itself (not the transceiver but rather the socket) on either of these switches is working properly. Would either of Sw1/Sw4 Gi0/1 ports come up if it was connected to a different and guaranteedly working fiber port/transceiver? Try to avoid interconnecting Sw1 and Sw4 Gi0/1-s in particular.
Also, can you try using the media-type sfp on the 2960 Gi0/1 port? Are you using genuine Cisco SFP/GBIC?
Best regards,
Peter
sabbinanti
Can you provide the running config for both swithces? All that is needed the the config for the interface on switch 1 connected to switch 4 and the config for the interface on swich 4 connect to switch one.
Sebastian
