Spanning VLANs - Multiple Sites
majick
We are opening a new office that is roughly 20km from another core site. We plan on provisioning 2 x DS3 between sites and likely have a requirement to support the same subnets (VLANs) at both locations. Let?s say we have our core site (SA1) and new site (SA2). Core infra will be at SA1 (WAN, Inet, Servers, etc).
SA1 has 2 x 6513?s running HSRP and VTP load balancing ? core of the LAN. Has anyone spanned VLAN?s across sites like this and know of any major concerns to watch out for in doing so? One concern is delays from L3 lookups to the remote MSFC?s ? MLS should help here for any cached routes/decisions.
5 Replies 5
bmahaffey-pelco
We are currently doing what you are talking about for some developers that need to see certain Layer 2 data @ our company but from the west coast to the east coast of the US with latency of 76ms and higher without any complaints.
L2TPv3 works great for this setup. Just requires advanced ip 12.4.10 and higher on the routers.
I haven't seen any issues and the tunnels have been up for over 6-7 months.
thanks for the info, it helps, we are planning to span approx 40 vlans with 450 users at new site. Is your setup is similar to what I mentioned and if you can provide some more details around actual implementation it would be great.
6509
trunking to router
7204
trunking on gi0/0
L2TPv3 Configuration
pseudowire-class vlan-xconnect
encapsulation l2tpv3
ip local interface Loopback1
ip pmtu
ip tos reflect
interface Loopback1
description L2TPv3 Tunnel Source
ip address 10.5.240.1 255.255.255.255
interface FastEthernet0/1.95
description L2TPv3 Tunnel VLAN 95
encapsulation dot1Q 95
no cdp enable
xconnect 10.5.240.3 95 pw-class vlan-xconnect
3845
trunking on gi0/0
ip pmtu
ip tos reflect
interface Loopback1
ip address 10.5.240.3 255.255.255.255
no cdp enable
xconnect 10.5.240.1 95 pw-class vlan-xconnect
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120s/120s23/l2tpv3.htm
You can either use GRE or L2TPv3, GRE seems a better fit for you than L2TPv3.
GRE is easier to configure also.
http://www.cisco.com/en/US/tech/tk827/tk369/tk287/tsd_technology_support_sub-protocol_home.html
Can you explain how to use gre for l2 trunking? I did not know this was possible other than using bridging.
oldcreek12
Wouldn't simple BCP configuration achieve what you want to do?
