ouch, if it's the only connection to this switch, it looks bad:-( The port is errdisabled (which means that it's as good as if it was down). Your only change to get it back up is if you had configured a recovery timer on the switch (errdisable recovery etc...). If not, the link will stay down until an operator brings it back up...
If you had the recovery configured, then make sure that the other switch is not sending BPDUs any more. You can achieve that with BPDU filter. BPDU filter could be dangerous if you had a redundant connection to this switch, but I guess that if this was the case, you would not be asking for help now.
Francois
