10-02-2007 03:35 AM - edited 03-05-2019 06:48 PM
Hi All
I need to configure spantree portfast and broadcast storms on all the interfaces on a live production switch. Can I do this on a production switch during production hours without impact to connecting users?
Solved! Go to Solution.
10-02-2007 07:18 AM
Adetutu
Yes you should be able to configure portfast and broadcast storm on a production switch during production hours without causing impact on users.
Rick
10-02-2007 07:18 AM
Adetutu
Rick
10-02-2007 08:10 AM
Thank you very much
10-02-2007 08:43 AM
Adetutu
Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read an answer that successfully resolved the question.
I encourage you to continue your participation in the forum.
Rick
10-02-2007 12:21 PM
When you enable this on each port, it will reset the port. This takes like 2 seconds. Users will get a reset popup.
10-02-2007 02:20 PM
Configuring portfast on an operational port should have no effect. In fact, portfast only does something when the link is coming up. Once a link is up, portfast does not change much to the operational state (it just prevents the transmission of TC indication on the port).
Francois
