Spantree portfast
Hi All
I need to configure spantree portfast and broadcast storms on all the interfaces on a live production switch. Can I do this on a production switch during production hours without impact to connecting users?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Spantree portfast
Adetutu
Yes you should be able to configure portfast and broadcast storm on a production switch during production hours without causing impact on users.
Rick
Adetutu
Rick
Thank you very much
Adetutu
Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read an answer that successfully resolved the question.
I encourage you to continue your participation in the forum.
Rick
When you enable this on each port, it will reset the port. This takes like 2 seconds. Users will get a reset popup.
Configuring portfast on an operational port should have no effect. In fact, portfast only does something when the link is coming up. Once a link is up, portfast does not change much to the operational state (it just prevents the transmission of TC indication on the port).
Francois
149
