Community Member
Speed and Duplex negotiation on the C2960G
Interconnecting a C2960G with other Cisco switches is not workable unless I set the speed/duplex at both end to Auto/Auto. If I hard-code to 100M/FULL, I get no link light at all, but it works fine if I connect to HP or Netgear switches.
This only happens with the C2960G.
Community Member
Re: Speed and Duplex negotiation on the C2960G
Purple
That is because you are using a straight thru cable with the 2960 , switch to switch needs a crossover unless you are using the auto mdix function which will only work as auto/auto and why you do not get a link trying to hardcode . If you feel the need to hardcode use a crossover cable. The hp and netgear switches probably use auto mdix on their end and why it works ok with those switches.
Community Member
Glen, This answers my question. It makes a lot of sense. Thanks!!!
185
