11-06-2013 10:24 AM - edited 03-07-2019 04:27 PM
I have a 3825 router feeding a network of 2950C switches with a vlan per switch. Is there any way I can set user speeds for example to 25 mb on each user port on the switches in the router? I know the 2950C will not do this in their configs and I am getting pushback about upgrading the switches 3550s.
11-06-2013 01:40 PM
You can't set the speed of each switch port of the 2950C from the router, however, you can set the speed on the VLAN found in the router.
11-06-2013 01:47 PM
If I am reading you correctly I can set speed per vlan, or can I set speed per ip address in the vlan? IE on a 24 port switch on say Vlan20 on each port can I have 25mb on each ip on the vlan or would I have to have 24 different vlans on the switch?
11-06-2013 02:22 PM
Per VLAN.
Everyone in that VLAN will have the same throughput. This is set on the router.
If your CEO is in this VLAN, then his/her speed gets throttled too.
11-06-2013 02:42 PM
Sorry for the ignorance. Would you mind posting up a basic config. So on the Vlan each ip with get say 25mb?
11-06-2013 02:50 PM
