SPEED/DUPLEX auto
what is the best config to ports on the Cisco Switch regarding Duplex & Speed;is auto config to both of them?OKK?
10XS
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: SPEED/DUPLEX auto
Hi Ali
The answer is it depends. If you are connecting servers and clients then as long as they are also set to auto neogitiate you should be fine.
Where i work we leave clients on auto-negotiation, any servers that are a 100full capable we set to 100full on the switch and gigabit server connectikns should be left at auto.
I have seen many problems with incorrect speed/duplex settings. The key thing is to make sure that the network people who set up the switches and the server/desktop people are all communicating.
Between switches you cause auto.
Jon
HI Ali
It will be fine if u r having auto at both the ends.
Mahmood
hi Mahmoud!
what about if these ports its conected to workstation>how come?
10xs
Hi Ali
Jon
Hi Jon/Hi Mahmood!
Thanks a lot for ur reply specialy in this off days
Hi Ali,
I Just have one comment to add:
If a switch port is configured with 100Mbps and Full Duplex (auto-negotiation is disabled -> no FLPs are sent), but the Workstation's NIC is configured for auto-negotiation --> Without auto-negotiation on the switch, FLPs (Fast Link Pulses) will not be sent to the workstation, and as a result, the workstation will configure itself to half-duplex (FLP was used to negotiate both speed and duplex), which can result in Duplex mismatch.
Switches detect duplex settings through auto-negotiation only. If both ends have auto-negotiation enabled, the duplex is negotiated. However, if either device on the cable disables auto-negotiation, the devices without a configured duplex setting must assume a default. Cisco switches use a default duplex setting of half duplex (HDX) (for 10-Mbps and 100-Mbps interfaces) or full duplex (FDX) (for 1000-Mbps interfaces -> Always Full can't be Half).
Duplex mismatch is a situation in which the switch is operating at full-duplex and the connected device is operating at half-duplex, or the other way around. The result of a duplex mismatch is extremely slow performance, intermittent connectivity, and loss of connection.
NOTE: If auto-negotiation is disabled on either end of the cable, the switch detects the speed anyway based on the incoming electrical signal.
Accordingly this is a thing that you need to consider in your network --> Either to make both sides Auto, or configure both sides explicitly to avoid any Duplex mismatch problems.
HTH and best regards,
Mohammed Mahmoud.
Another adding if i may...
If the switches ar config for auto a trunk won't be negotiated cause both switches are waiting for the ohter to start the negotiation...
I have also had an issue that i had to config my router which only had 10 mb interfaces like this...
on the routers - duplex full
on the switches - speed 10 and duplex on auto
ciao flash
970
