After setting a switchport to 100 Full Duplex, what IOS command can we use to determine that the laptop client has been set to 100 Full Duplex as well?
You can use the 'SHOW INTERFACE' command to verify the port is not taking errors due to mismatches. But you are not able to see what the host has renegotiated to from the switch.
