srr-queue bandwidth limit 70 command not work in Cisco 3750
csawest.dc
Level 3
Level 3
Dear Experts,
I have Cisco 3750 (24) P switch, i need bandwidth resctrict 30 mb on interface fa1/0/1 , but it's exceeded more than 40 mb
interface fas1/0/1
no switachport
ip add 192.168.1.1 255.255.255.0
but when i check after given this command bandwidh exceeded more than 30 or 40 mb it's not rescrict.
so what is the issue and how can i solve this.
Please help me
Souvik Ghosh
Then bandwidth limit command will limit the bandwidth of the interface specified as percentage along with the command. So in order to limit the bandwidth ot 30 Mb on a 100 Mb interface please use  srr-queue bandwidth limit 30 under the interface. Also it seems you have already enabled mls qos globally ( this is needed).
Rgds,
Souvik
Souvik Ghosh
Rgds,
Souvik
Dear Souvik,
Thanks bro have good explanation, i will try to give this command and then let you know what heppand.
switch(config)#msl qos
switch(config)#int fa1/0/1
switch(config-if)#no switchport
switch(config-if)#ip add 192.168.1.1 255.255.255.0
switch(config-if)#srr-queue bandwidth limit 70
Thanks once again!!!
Dear Friend,
I configure "mls qos" command in global mode Cisco 3750 switch and then apply "srr-queue bandwidth limit 70 on int fas0/2
but bandwidth exceed more than 40 mb.
I need 30 mb bandwidth limit on int fast 0/2
swtich(config)#mls qos
switch(config)# int fas0/2
switch(config-if)# ip add 192.168.1.1 255.255.255.0
but still bandwidth exceed more than 40 mb through fas0/2 interface
what config i need to achive this
Thanks in ADV,
You need to run "srr-queue bandwidth limit 30" on interface to limit the bandwidth to 30Mbps
