Community Member
SRW208: IGMP Snooping not working!
Hi all,
at the moment we have some trouble with the following SRW208 setup:
- Port mirroring is enabled (Port 8 mirrors Port 1) for sniffing via Wireshark in promiscuous mode.
- "IGMP Snooping" is enabled
Our test scenario:
- an IPTV settop-box is connected to port 1 and it gets all traffic from a VDSL router connected to port 2.
- one wireshark PC sniffs at mirror port 8 (all traffic) in promiscuous mode
- one wireshark PC sniffs at port 3 (all traffic) in promiscuous mode
With IGMP snooping enabled only the wireshark PC at (mirroring) port 8 should be able to sniff the mcast traffic between the settop-box and the VDSL router.
The problem is that wireshark at port 3 can sniff all mcast traffic, too. In addition the LED of all ports are blinking synchronously/continuously.
It seems that the IGMP snooping does not to work properly and all port are still flooded with the mcast traffic.
Is this a known problem of the srw208?
Cheers, Fred
Update: With an old Zyxel switch the setup works w/o problems.
267
