12-14-2007 04:48 AM - edited 03-05-2019 08:00 PM
I have C3548-XL and C3508G-XL switches in my network. Would they support SSH for CLI login? They currently have IOS Version 12.0(5)WC13 in them. Please suggest.
Subbu
12-14-2007 04:56 AM
Subbu
If the image in the switches supports encryption then they should support SSH access. We can not tell from what you posted whether the switches do support encryption or not. It is a function of which feature set they are running more than a question of what version they are running. If you would post the output of show versions from the switches we could tell which feature set is running.
Rick
12-14-2007 05:12 AM
Thanks for the response Rick. Here is the show version output.
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3f), RELEASE
SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 18-Aug-06 18:47 by alnguyen
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
Rtr uptime is 15 weeks, 4 days, 20 hours, 29 minutes
System image file is "flash:c2800nm-ipbase-mz.124-3f.bin"
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
12-14-2007 06:29 AM
Your version is not SSH capable, so you should to upgrade your IOS to IP Base With Encryption : c2801-ipbasek9-mz.
You can take a look on this page :
http://www.cisco.com/en/US/products/ps5854/prod_bulletin0900aecd802a9493.html
Plz rate if it helped.
12-14-2007 09:21 AM
Ok I'm confused you asked about 3500 switch images and then you post a show version for a 2800 router . Routers will usually have a k9 or k2 in the image version if they suypport SSH.
12-14-2007 09:27 AM
Theres defintiely a way of finding out by examinign th enomenclature of the file name.
However, as a quick and dirty test, just try ebtering the following commands to enable SSH.
ip ssh
crypto key generate rsa
If they work, then the IOS supports SSH. if not, .....
12-14-2007 06:54 PM
The 3500XL Series switches do not support ssh at all. Since these switches are End Of Life, there won't be future software for them either. If you require secure access to these older devices, because of something like audit requirements - the best way (without replacing the switch) is to use a console server (like a Cyclades) that supports ssh, which would then connect to the serial console port of each switch.
Scott
