ssh ios for WS-C2960-24PC-L
gopi_b4u2003
HI,
Which ios version will support for ssh in WS-C2960-24PC-L. Now i am having with c2960-lanbase-mz.122-44.SE3.
Kidnly do the needfull.
Thanks in advance
5 Replies 5
Lucien Avramov
Level 10
Level 10
You need a version with crypto (k9).
Example:
c2960-lanbasek9-mz.122-52.SE.bin
c2960-lanbasek9-tar.122-52.SE.tar.
The tar file has also a web manager with it, compared to the bin file.
thanks . can i know the software version of this IOS.
Thanks in advance
gopinath
Gopinath,
You need a "k9" IOS to do so. Let's say "c2960-lanbasek9-mz.122-44.SE3.bin".
HTH,
Toshi
Gopinath,
Currently you have a 12.2(44)SE3 and the ones mentioned by Lucien are 12.2(52)SE
HTH, Ingolf
I told this version as anyways you will have to upgrade your image to a k9, might as well go to 52 SE.
