SSH on 6509 8.1(3)???
Hi all, I need to configure SSH on a 6509 running 8.1(3). I just wanted to know if SSH is supported?
Any help would be greatly appreciated.
Brian B.
1 ACCEPTED SOLUTION
Re: SSH on 6509 8.1(3)???
Hi Brian,
I am attaching the same doc as .pdf file and you can download from this post.
Ankur
*Pls rate all helpfull post
Hi Brian,
See if this link helps you
http://www.cisco.com/en/US/partner/tech/tk583/tk617/technologies_tech_note09186a0080094314.shtml#Req
Ankur
I wasnt able to login to the website, it asked for cisco user name and password, i have CCO account but it didnt let me in :(
Hi Brian,
Ankur
Purple
You have to have the K9 image of catos software to run ssh . If it is a K8 image it is not supported . Also catos does not have a built in ssh client which means you cannot ssh from a catos box to another ssh device . Any catos image that has K9 as part of its name should support ssh.
Glen thank you, that was exactly what i wanted to know.
Brian Buryak
157
