While using the hardware feature of the Software Advisor for Cat 4003/4006 running CatOS, it recommends a K8. Will this do and what is the difference. Why a K8 and not a K9?
For SSH you need K9 images for sure. You dont need K8 images and will not work for you. I think there is some problem with the software advisor. Please look at the release notes below.
