SSH v2.99 on 4507 switch, CiscoWorks can not pull configs
I have version 2 ssh configured on a Cisco 4507r-e.  Unable to sync archives with CiscoWorks.  V2.99 is unsupported on CiscoWorks.  Does CiscoWorks need to be updated or does the switch?
cat4500-ipbasek9-mz.122-52
LMS 3.2
# show run
ip ssh version 2
#show ip ssh
SSH Enabled - version 2.99
1 REPLY
Bug ID CSCsq51052
Fixed in 12.2(54)SG
Workaround:
The following workaround can be implemented if the ouput of the "show ip ssh" command indicates version 2.99, as in the following example:
Router#show ip ssh
Authentication timeout: 120 secs; Authentication retries: 3
Router#
If version "2.99" is reported, proceed to configure the required SSH version, ie:
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#ip ssh version 2
Router(config)#end
The execution of a "show ip ssh" command should now indicate the correct version:
Router#show ip ssh
SSH Enabled - version 2.0
Router#
826
