SSH won't work on cat4500es8-universalk9.SPA.03.03.00.XO.151-1.XO.bin,
kdaramola
                  I just graded from none k9 code to k9 above but i was unable to config SSh  fesatures. Any suggestion
21 Replies 21
Hello
When you was unable to config SSH what wasnt you allwed to do?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
I can only telnet .  I need to enable ssh. but command won't work somehow.
You did configure all of this requirements:
  1. Configure the hostname command.
  2. Configure the DNS domain.
  3. Generate the SSH key to be used.
  4. Enable SSH transport support for the virtual type terminal (vtys).
HTH,
Dragan
HTH,
Dragan
Hostname  and dns are configured just like other switchs.
but any ssh command won't work. i try crypto key generate rsa  or set crypto key generate rsa .
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSAL-M), Version 03.03.00.XO RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 14-Aug-13 09:51 by prod_rel_team
boot-start-marker
boot system flash cat4500es8-universalk9.SPA.03.03.00.XO.151-1.XO.bin
boot-end-marker
And did "crypto key generate rsa" passed fine? Did you generate keys?
HTH,
Dragan
HTH,
Dragan
Crypto key command doesnot work. it not taking it.
4510R#sh bootvar
BOOT variable = cat4500es8-universalk9.SPA.03.03.00.XO.151-1.XO.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x2101
Standby BOOT variable = cat4500es8-universalk9.SPA.03.03.00.XO.151-1.XO.bin,1;
Standby CONFIG_FILE variable does not exist
Standby BOOTLDR variable does not exist
Standby Configuration register is 0x2101
You can't even type "crypto"? No option after that?
Could you post option after "crypto" command if you even can put that one on platform?
HTH,
Dragan
HTH,
Dragan
Correct . it won't take Crypto at all.
Can you do this and post the commands and any output
config t
crypto ?
This might help us to understand your issue. Certainly that code that you show us should support crypto commands.
Rick
Rick
Enter configuration commands, one per line.  End with CNTL/Z.
4510R-CORE(config)#crypto ?
% Unrecognized command
Can you maybe enter something like "ip ssh..."? Could you try that?
SSH should definitelly work on your platform...
HTH,
Dragan
HTH,
Dragan
kdaramola
4510R-CORE(config)#ip ssh ?
Jon Marshall
When you upgraded did you leave the original IOS in flash as well ?
If so then it may be your configuration register ie.
0x2101 means load the first image found in flash ie. ignore the boot variable
0x2102 means load the image specified in the boot variable
do a "sh ver" to see which image you are running. If it is the none crypto image then change your confiiguration register to 0x2102 and reload.
Then try ssh again.
Jon
