SSL module not sending certificate expiration notice
hoffa2000
Level 3
Level 3
Hi all
Has anyone had any experience with this feature on the SSL module?
I've set the "ssl-proxy pki certificate check-expiring interval 1" command and has a syslog and SNMP receiver up and running. Logging is set to debug both for buffer and syslog.
The thing is that I have a proxy service with a certificate that's about to expire tomorrow and there is notification either in the log buffer or on the syslog.
/Fredrik
mchin345
Level 6
Level 6
The ssl-proxy pki history command enables logging of certificate history records per-proxy service into memory and generates a syslog message per record. Each record tracks the addition or deletion of a key pair or certificate into the proxy services key and the certificate table.
Up to 512 records can be stored in the memory at one time.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ssl/3.1/command/reference/comref.html#wp1008891
Do you have following traps configured
snmp-server enable traps ssl-proxy oper-status
snmp-server enable traps ssl-proxy cert-expiring
snmp-server host ssl-proxy
Syed
