09-10-2014 09:02 AM - edited 03-07-2019 08:42 PM
I have an existing stack of two 3750V2 switches and I would like to add a 3750X to it.
Existing stack:
Switch Ports Model SW Version SW Image
1 26 WS-C3750V2-24PS 12.2(50)SE5 C3750-IPSERVICESK9-M
* 2 26 WS-C3750V2-24PS 12.2(50)SE5 C3750-IPSERVICESK9-M
Switch to add:
* 1 30 WS-C3750X-24P 12.2(55)SE5 C3750E-UNIVERSALK9-M
Right now, I understand that I will need to upgrade the IOS of the existing stack to 12.2(55)SE5 since the (50) individual release is not available for the 3570X.
The issue I am anticipating is the license incompatibility. The new switch has an 'ipbase' license. The existing stack has no license. If I do a 'show license detail' I get the following message/error '% License not supported on this device'.
Will this be an issue or should I be OK in just upgrading the existing stack and adding the new switch?
09-10-2014 10:36 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The pre-E/X 3750s license is a "paper" license. I.e. the installed image provides the feature set.
Your 3750V2s are running IP Services.
I think they will allow the 3750X, to join the stack, with just an IP Base license (ideally with same IOS version).
09-10-2014 11:04 AM
The "paper" license is new to me so thank you for explaining that. I didn't anticipate an issue with the IOS.
thank you
