01-24-2015 02:43 AM - edited 03-07-2019 10:22 PM
I have a stack switch with 8 switches 3750 and one of stack member be restarted!
this happen several times
what is reason this problem?
Solved! Go to Solution.
01-24-2015 03:54 AM
we need to findout the reason.
01-24-2015 03:54 AM
01-24-2015 04:16 AM
yes I need to find out restarting switch reason!
01-25-2015 05:13 PM
Hi Masoud,
Could you please send me the show tech output from the system and also the crash info?
If you feel that you cant share it public send me PM.
REgards
inayaht
01-26-2015 12:06 AM
Hi Masoud,
You have to find out there is any hardware related issue on the particular switch such as loopback failure, fan failure and etc. temporarily remove the particular switch from the stack and reboot the switch and see the switch loading over the console.
before that,just try this command in the stack
show environment all.
this command will tell you if you have any hardware issue
01-26-2015 03:17 AM
Hi jayaratnam,
I checked fan, power and temperature of all switch. all of theme is ok.
all switch have 1 power and did not used power sharing mode that is in stand alone mode!
the switch that was restarted have lowest priority in stack!
In your opinion if I use power sharing mode on stack with stack power cable this problem can be solved!
