stack with 3750-48TS
Hi:
Should I connect the port-1 of the swith-1 to the port-2 of the swith-2 to enable the stack?
What happen if I use the port 1 in both switches? It should work, right?
Regards.
1 REPLY
Purple
Re: stack with 3750-48TS
Yes port 1 to port 2 on the 2nd switch . If you add a 3rd , it would go 1 to 2 on the third and then you would run port 1 on the 3rd switch to port 2 on the first switch to make it redundant.
108
