Stacking 3750 switches
Can you mix TS with PS models when stacking 3750's?
1 ACCEPTED SOLUTION
Silver
Re: Stacking 3750 switches
Hi, Cat3750s no matter their port density or model are meant to be stacked.
A stack can be made from PoE, Non-Poe and even the 3750-E series switches.
They just need to have the same IOS version.
This doc tells all you need to know about stacking 3750s
Managing Switch Stacks
https://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_40_se/configuration/guide/swstack.html
Silver
VIP Super Bronze
Yes, from the data sheet:
Stacks can be created with any combination of Cisco Catalyst 3750 and Cisco Catalyst 3750-E switches. Customers who need a mixture of 10/100 and 10/100/1000 ports, PoE, and wiring-closet aggregation capability can incrementally develop the access environment, paying only for what they need. When uplink capacity needs to be increased, you can easily upgrade your bandwidth by adding a 10 Gigabit Ethernet version to the stack and upgrade your Gigabit Ethernet links with 10 Gigabit Ethernet on the existing fiber.
Reza
Thanks for both replies. That solved my question. This will definitely help as I clean up IDF's across campus.
This forum is great! Again, thanks
311
