stacking Cat 2960 to Cat 2950
How do i accomplish this I have a network using 2950's and 2960's Can they be stacked together with a gigabit module
Re: stacking Cat 2960 to Cat 2950
Nope, this is not possible.2960' switches doesnot support gigabit stacking modules. They have only SFP ports that can be used for fiber uplinking.
http://www.cisco.com/en/US/products/ps6406/products_qanda_item0900aecd80322c37.shtml
HTH,please rate if it does.
-amit singh
I think you mean Clustering both Switches. Clustering is possible between both Switches. The only major benefit you will get is save 1 IP address for the management interface if you want. Just download the CNA (Cisco Network Assistant), it is free and gives you Windows interface.
as far as I know Stacking option is only available in 3750's with the use of Stackwise cable. You cannot stack even if you have 2x2950's, but sure you can Cluster them together.
Shaheen
I have a similar question. I have just "inherited" a network containing a combination of cat 2950s and cat 2960s. The network is on three floors with 2 cat6 links between floors 1 - 2 and floors 2 - 3. I am in a position to optimise this network and was wondering about the best options for linking the switches together.
136
