stacking WS-C3750X-24P with WS-C3750G-24PS
HI
I'm having trouble stacking a new WS-C3750X-24P with existing switches WS-C3750G-24PS
I can see the license is on the  new WS-C3750X-24P:
switch#sho lic
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: 0  minute  0  second
Index 3 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Switch#sho ver | i uni
System image file is "flash:/c3750e-universalk9-mz.122-55.SE1/c3750e-universalk9-mz.122-55.SE1.bin"
I’m not sure if we need to change the new switch to an IPBASE image to be compatible, with the existing switches …..
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24PS     12.2(55)SE1           C3750-IPBASEK9-M
I could put on the c3750e-ipbasek9-mz.122-55.SE1 image, but I may need to get the license sorted still, but not sure if that will work or how to add it if i got one.....
Any help would we great
thanks
phil
1 ACCEPTED SOLUTION
VIP Super Bronze
Phil,
You can stack any combinations of 3750 series together as long as you have the same exact IOS and license.
To add a swith to an existing stack follow this link:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#Add
VIP Super Bronze
Phil,
Thanks, i understand that if they have the same IOS and lic that , i'm just need doing to know specifially how, you get them to stack. As i can't put the 'universail' image on the 3750G and am unsure about how the license works/installed.
Should i install c3750e-ipbasek9-mz.122-55.SE1 image on the E , so they are on the same 22.55.SE1 and then how do i do the license?
Or is there an image i can up on the 3750G that will work?
thanks
phil
669
