Standby blade switch 3030 upstream port-channel flapping updown
Denny Zhang
show logging
May  1 16:00:30: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/12, changed state to down
May  1 16:00:39: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/12, changed state to up
May  1 16:17:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/12, changed state to down
May  1 16:17:36: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/12, changed state to up
May  1 16:25:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to down
May  1 16:25:37: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up
May  1 17:19:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to down
Configuration as below:
macro name vmware
switchport mode trunk
no switchport access vlan
link state group 1 downstream
spanning-tree portfast
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh authentication-retries 2
ip ssh version 2
interface Port-channel1
link state group 1 upstream
interface GigabitEthernet0/1
speed 1000
macro description vmware
interface GigabitEthernet0/2
speed 1000
interface GigabitEthernet0/3
speed 1000
interface GigabitEthernet0/4
speed 1000
interface GigabitEthernet0/5
speed 1000
interface GigabitEthernet0/6
speed 1000
interface GigabitEthernet0/11
channel-group 1 mode active
interface GigabitEthernet0/12
sh link state group de
Link State Group: 1      Status: Enabled, Up
Upstream Interfaces   : Po1(Up)
Downstream Interfaces : Gi0/1(Up) Gi0/2(Up) Gi0/3(Up) Gi0/4(Up)
                        Gi0/5(Up) Gi0/6(Up)
(Up):Interface up   (Dwn):Interface Down   (Dis):Interface disabled
Note:
Both active blade switch and standby one are connecting to same aggregate switch 3750. Yet the active one, with same config as standby one, has not occurred this issue.
Andrew Cink
Post the relevant config from the 3750 side? For the ports connecting to both the active and standby blade?
Andy
!port-channel10 attched to active blade switch
interface Port-channel10
switchport nonegotiate
interface GigabitEthernet1/0/3
description blade0102 port 01/01
channel-group 10 mode active
interface GigabitEthernet1/0/4
description bladechassis0102 port 02/01
!port-channel10 attched to standby one
interface Port-channel11
interface GigabitEthernet2/0/3
description blade0102-3 port 11x
channel-group 11 mode active
interface GigabitEthernet2/0/4
description blade0102-3 port 12x
sh lacp nei
Channel group 10 neighbors
Partner's information:
                  LACP port                        Oper    Port     Port
Port      Flags   Priority  Dev ID          Age    Key     Number   State
Gi1/0/3   SA      32768     0017.95e5.5180   6s    0x1     0xB      0x3D
Gi1/0/4   SA      32768     0017.95e5.5180  24s    0x1     0xC      0x3D
Channel group 11 neighbors
Gi2/0/3   SA      32768     0017.95e5.5f80  17s    0x1     0xB      0x3D
Gi2/0/4   SA      32768     0017.95e5.5f80  10s    0x1     0xC      0x3D
