Static route leaking between two vrf's on Nexus 7000 switch
I want to create following setup, wanted to know that how this is achievable.
N7K-VRF-A-----------------------------------------------------N7K-VRF-B
Vlan 1        Vlan 2
int vlan 1        int vlan 2
ip add 10.10.10.1        ip add 20.20.20.1
  SERVER-1        SERVER-2
(IP-10.10.10.10)        (IP-20.20.20.20)
Now I want SERVER-1 should speak to SERVER-2 and i want to exchange routes betwene VRFs through Static route leaking.
1 REPLY
Re: Static route leaking between two vrf's on Nexus 7000 switch
Hi Pravin,
Don't think you can achieve that via static route. If you have spare ports, you can do it via physical loopback cable. Otherwise you just need leak it via BGP.
HTH,
Lei Tian
278
